Don Key Hotay
I believe my well pump check valve might be faulty.
The issue is that the plumbing system will slowly lose pressure, such that the pump cycles about every 40 minutes without any water usage in the house. I do have a toilet that has a very minor leaky flush valve which couldn't possibly account for the frequency of the well pump cycling.
My air tank holds proper pressure and does not appear to be taking on water. I also eliminated the possibility of leaks from our outdoor water fixtures, by shutting off all outside plumbing.
So, here goes my question: If the pump cycles and fully pressurizes the system, then I turn off the pump at the breaker, should the plumbing system stay at constant pressure for several hours or indefinitely? If it does not stay pressurized, would the check valve be a likely culprit?
Many thanks for any info you can provide!
