water valve vs gas valve
ozntz
Jan 7, 2010
Is there any difference between the two? Put in a valve for my sprinklers I had it installed before I noticed I had grabbed one rated for gas. Worked for a couple months so far :)
majakdragon
Professional
Professional
Jan 7, 2010
297
Lafe Arkansas, Arkansas
While there are specialty valves, most have a rating stamped on them. You will see WOG on the side. This stands for Water, Oil or Gas. Most gas valves are brass and much heavier than standard valves, The other difference is most gas valves open or shut off with 1/4 turn. Ball valves also work the same way. Using a gas valve for water is more preferable than using a water valve for gas. Gas valves seal better.
