CliffG
I have this problem for several weeks now with water trickling in from the tank into the bowl, after a few minutes the water valve turns on and fills the tank back up. I have replaced the flapper which didn't solve the problem. I have also replaced the flapper valve and tank to bowl gasket and the water is still trickling and the water valve is still running when the tanks gets a little low. I'm not sure what else I can do to resolve the issue.
FYI - I replaced the water fill valve about 6 months ago with a fluidmaster universal kit and it I didn't have the problem until about 2 weeks ago.
Any ideas what might be causing the water to trickle? How I can fix it?
Thanks!
Thanks!
