Water seeping up through kitchen floor!
Discussion in 'General Plumbing Help' started by Jen, Jan 19, 2020.
  1. Jan 19, 2020 #1
    Jen
    Jen
    Jen
    Jan 19, 2020
    Cuyahoga Falls OH
    I live in a home on a concrete slab. Wednesday night I noticed small puddles of water on kitchen floor, thought it was a spill, by Friday I continued to see water and have my socks soaked through so I knew it wasn’t just spills or from snow. Saturday I pulled up the loose tile in the adjoining mud room and saw significant water. Dried water and realized it was streaming out of a small hole in the wall that runs behind my cabinet and dishwasher. Turned off hot and cold water under sink, put towels around the leaking wall. Cold water continues to leak drenching a full towel in an hour or two. Cold water continues to rise from tiles 3/4 of the way across my floor from dishwasher/sink. Water dial on my meter is not spinning. Towels on tiles are soaked in two hours. Cabinet foot board that runs under sink and next to dishwasher is soaked. Cabinet bottoms and under sink is dry....plumber coming out tomorrow morning but any ideas what I am looking??? Single mom without ton of money budgeted for something like this....should I be contacting my homeowners insurance?
  2. Jan 19, 2020 #2
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,354
    403
    North Reading, Mass.
    Assume you have never had ground water problems at this house in the past but have you been getting a lot of rain lately?
    Turning off hot and cold under sink would not stop water leaking from behind the walls or in the floor. You must try shutting the main valves back in some utility room or area where the hot water source or main cold water source would be coming from.
    Jeff Handy likes this.
  3. Jan 20, 2020 #3
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,268
    215
    Chicago suburbs
    Don’t call the insurance company unless you are certain you need to make a claim.
    IF the problem is even covered, you should probably just try to eat the cost if it is under $750 to $1000 or so.
    Try to negotiate installments with the plumber.
    Maybe make him a nice lunch, you might fall in love and all live happily ever after!
    Some insurance companies will raise your rates right away, and some will give you one claim before raising you.
    But then comes your next claim, maybe your roof blows off or there is a fire, or you get robbed, whatever.
    Now you are already on their short list to be dropped, and they will pay your claim then might try to dump you, or jack your rates sky high.
    If you get dumped, other companies will know about it.
    And worst of all, some companies will charge you with a “zero cost claim” if you just call to ask if something might be worth claiming.
    Still counts against your record!
  4. Jan 20, 2020 #4
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,268
    215
    Chicago suburbs
    PS Even though the water seems cold, make sure it is not coming from the water heater.
    If you turn off all the house water, and the water heater is leaking, then turn off the water heater also, to avoid it burning up.
  5. Jan 22, 2020 #5
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    1,032
    218
    Mansfield,, Ohio
    It sounds like you have a pin hole leak on a pipe that's under ground. Check all your visible pipes and make sure there
    are no leaks. Let us know what your plumber found.
  6. Jan 23, 2020 #6
    Geofd
    Geofd
    Geofd
    Moderator Staff Member Professional Supporting Member
    Jan 20, 2018
    1,603
    238
    Boston, Massachusetts
    i had something just like that the family spent most of their time drying towels,water came right thru a flag stone floor,they had 2 hotwater heaters in the house,on for the main house,on for the guest apt with only myself and the owner home no fixtures being used,the main house hot water heater was firing....i shut of that feed and the water stopped.......the hot water line was broken in the foundation....it effected the second floor bath with out a major reno that they could not afford, i install point of use hwh...just for the sink.....they did have another bath for showering
  7. Jan 23, 2020 #7
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,603
    238
    jeff know you really have me thinking when i type my posts!!!!!!!!!!
    just thought of something else....you keep saying cold water,meter not spinning, have you had the city/town come out and check the water main BEFORE your meter
    you never know.......
  8. Jan 23, 2020 #8
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,603
    238
Draft saved Draft deleted
Share This Page
Group Builder
