your howling
i had a ceramic disc in a kitchen sink go bad, when the water was used it made a growling noie that made the dog and cat run and hide
a prv will not register the change in psi when it is lowered, till you open then close a valve
because the psi in the pipe is what it is, till it is bled off . savvy?
Yeah makes total sense and I did run the water between tests but I may not have run it long enough.
