My water pressure drops from 50 PSI to 20 and kicks the well pump on about every 42 minutes. I have a shut off between the pressure tank and the house plumbing and have closed that valve but it did not change the timing so I know it is not a leak in the house. I just moved into this house and was told by the “well guy” that he installed a new foot check valve last year. His conclusion is that since the new foot valve didn’t fix the problem then I need to put down a new well because it probably has a cracked casing. Can a cracked casing cause this problem? Thank you.
