Water pipe "bursting" like drain "bursting".
Sorry for my input guys. I'm just a dumb layman but just want this answered. How can there be a maximum flow rate of 2.3 GPM? Does this not matter on how much pressure is introduced through the tubing?
rule of thumb,,,pressure drop of 3.5 psi per 100' of run
600' -21 psi drop, op says 65 psi at house house bib with water running at shower/ sink in house
i doubt this very much
i am calculating 45 psi at meter minus 21 psi for pressure drop
23 psi at house...
Unless there is 86 psi at the meter which brings it to 65 at the house, I also cant figure that a 1/2" supply can run a sink shower and hose bib keeping 65 psi unless all were reduced to 1/16" like a pressure washer tip. I have 1" supply lines and a 40' run and I can't run my shower sink and hose at the same time maintaining pressure.
110 psi at house. Like I said it's working. Flow rate on 1/2" is 14 gpm. Just open your full flow hydrant on wall fill that 5 gallon in 20 -25 seconds that's very roughly 14 gpm. Proof in da pudding fellas
My 3/4" hose bib off my 3/4" supply line takes almost a full minute to fill a five gallon bucket.
