Water line size from street
Atn311
May 18, 2021
5
San Antonio, Tx
I had a plumber come do an estimate on my house stating the line from the street had to be replaced because it wasn’t code due to my home having two bathrooms. What is the code for this? San Antonio follows the 2018 IPC. Is this right?
Twowaxhack
Professional
Professional
Feb 9, 2021
4,224
1,851
United states
IPC written by the ICC.
minimum is 3/4” for a home. Most homes here with two baths at 60 psi uses a 1” water service.
JG plumbing
Mar 26, 2021
1,443
512
Iowa
I'm not sure exactly the perameters, but it's illegal to distribute copies of the plumbing code. @Twowaxhack you just ripped the tag off your mattress bro
FishScreener
Aug 23, 2018
557
203
83467
Call the Authority Having Jurisdiction, and ask them. Generally the ICC codes are used as templates for legally adopted local codes. And the local/county/state government all will make changes in the ICC codes before adoption. A few more stringent, and most less stringent. For example the International Residential Code, requires fire sprinkler systems. But, very few jurisdictions have adopted that section of the code. Idaho, has it’s own plumbing code, electrical code, and mechanical code. They don’t require sanitary yard hydrants, they just this year started to require Arc Fault protection in bedrooms.
I work for the Federal Government, and we by act of Congress have adopted the ICC codes in their entirety, with only a Cabinet Secretary authorized to make modification to it. So, when we put in solar power at sites in the Wilderness, we have to put the anti back feed devices in. Even though the nearest power line is forty miles away, and will never be extended through the wilderness area.
Twowaxhack
Professional
Professional
Feb 9, 2021
4,224
1,851
United states
I agree with Fishscreener to call and ask.
It doesn’t matter to some jurisdictions what the code says, they enforce “ what they like “ and some of that isn’t even written anywhere. So it’s not even code.....but it is until you hire a lawyer.
Don’t get me started.......
Atn311
May 18, 2021
5
San Antonio, Tx
Thanks for all your help. I paid for the work out of pocket and I’m just trying to get the insurance company to reimburse me. The plumbing did need it. House was built in 1953 but I’m not sure when the plumbing was done because I just bought it last year. But it wasn’t up to code apparently.
