Water leak issue
Discussion in 'General Plumbing Help' started by Geekfather, Aug 28, 2018.
  1. Dec 7, 2018 #61
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,196
    370
    North Reading, Mass.
    The bottom line, as far as I am concerned, it is poorly written. And if I wasn't retired, I know I could get them to clarify it in writing. I don't remember what they officially called it but we were able to pose questions and they would answer them in writing.
    If it wasn't poorly written, we won't be having this discussion.:D
  2. Dec 7, 2018 #62
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,759
    2,404
    I am an old Uniform Plumbing Code plumber
    That code has a LOT more detail than this Micky mouse international code
    The IPC, in my opinion leaves a whole lot of info out.
    and what REALLY freaked me out was in 504.6-5 it says the pop off can be terminated into the pan
    WAT???? In UPC that is a huge red tag, a no no
    a Gibbs slap for sure.
    GReynolds929 and Diehard like this.
  3. Dec 7, 2018 #63
    Mikey
    Mikey
    Mikey
    Well-Known Member Supporting Member
    Jul 16, 2018
    262
    43
    Northwest Washington
    No attics, thank goodness, several garages. But I disagree - the way I read 504.6, all 11 criteria must be met. I see nothing in 504.6 that implies the PRV discharge criteria can be divided into to sections as you/ve done, A (1-5 1/2) or B (5 1/2-11). It says the discharge piping shall (italics mine) comply with all 11 criteria, one of which (504.6(2)) is that it must discharge through an air gap located in the same room as the water heater. Once it's gone through the air gap, it also has to comply as described in 3-11. If you do indeed stick in the "or" as you've marked, you could discharge (after the air gap) to an attic floor, and thereby not comply with (6).
    The pan drain is another issue, which may be why it's in a separate section.
    Of course, what either one of us thinks matters little when the local authority having jurisdiction is having a look at our finished work.
Draft saved Draft deleted
Share This Page
