Water heater advice...
Discussion in 'General Plumbing Help' started by steph746, Dec 29, 2016.
  1. Jan 5, 2017 #61
    Deerslayer
    Deerslayer
    Deerslayer
    Dec 14, 2016
    57
    26
    I'm pretty sure atmospheric 75 gallon heaters are no longer available?
  2. Jan 5, 2017 #62
    voletl
    voletl
    voletl
    Dec 18, 2014
    652
    200
    New York
    Yeah I think anything over 50 gallon now has to be direct vent
  3. Jan 5, 2017 #63
    steph746
    steph746
    steph746
    Dec 1, 2016
    24
    I see..can direct vent be vented out of a chimney?
  4. Jan 5, 2017 #64
    voletl
    voletl
    voletl
    Dec 18, 2014
    652
    200
    New York
    Yeah if you run the PVC pipe all the way down your chimney the point of a direct vent besides being more efficient was to eliminate the need for a chimney
  5. Jan 5, 2017 #65
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    do your research first. you are only allowed X amount of 90's on a direct vent
  6. Jan 6, 2017 #66
    steph746
    steph746
    steph746
    Dec 1, 2016
    24
    Sorry...not sure I follow you. What are "90's"?
  7. Jan 6, 2017 #67
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    on your vent, a 90 is a 90 degree offset.
    in the literature that comes with the unit. they will tell you, you can offset "X" amount of degrees
    you can not go over that. last unit I installed was allowed 180 degrees in offsets
    that is 2, 90 degree turns. and 3' total horizontal run
  8. Jan 6, 2017 #68
    Deerslayer
    Deerslayer
    Deerslayer
    Dec 14, 2016
    57
    26
    Direct vent DOES NOT USE PVC OR EXISTING CHIMNEY
    KULTULZ likes this.
  9. Jan 6, 2017 #69
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    not a Junior Member anymore! Sponsor
    Mar 9, 2016
    774
    145
    NOKESVILLE, VA
    Bradford and State both still have an atmospheric 75
  10. Jan 6, 2017 #70
    Deerslayer
    Deerslayer
    Deerslayer
    Dec 14, 2016
    57
    26
    Not in residential?
  11. Jan 6, 2017 #71
    KULTULZ
    KULTULZ
    KULTULZ
    Jack of All Trades ~ Master of None Professional
    Sep 4, 2011
    1,534
    316
    Between Lost And Found, W (BY GOD) V
    EXCERPT SOURCE-http://plumbingengineer.com/content/pvc-acceptable-vent-material-flue-gases
  12. Jan 6, 2017 #72
    steph746
    steph746
    steph746
    Dec 1, 2016
    24
    Direct Vent or Atmospheric Vent units would have relatively the same efficiency? The difference is that they just vent differently? The current tank vents out the chimney. My thought was to replace it with an atmospheric tank that would vent out the chimney as well. I might have to have the chimney lined, but I would prefer that since I would not have to have another hole in the house.
    However, if a direct vent tank would be more efficient, I would go with that and have the hole created for a direct vent.
  13. Jan 6, 2017 #73
    Deerslayer
    Deerslayer
    Deerslayer
    Dec 14, 2016
    57
    26
    A direct vent uses outside air vs conditioned air for combustion that is how they gain efficiency.
  14. Jan 6, 2017 #74
    voletl
    voletl
    voletl
    Dec 18, 2014
    652
    200
    New York
    So please inform me what materials you use to vent.
    So I'm just going to think that all the manufacturers of the water heaters who send PVC fittings with the the water heater are clueless and not to even mention high efficiency furnaces that use PVC for flue
    And you can reuse the existing chimney as long as the pipe is brought down through the chimney and then connected to the water heater.
  15. Jan 7, 2017 #75
    Deerslayer
    Deerslayer
    Deerslayer
    Dec 14, 2016
    57
    26
    Power vent heaters use PVC typically. Direct vent uses metal venting
  16. Jan 7, 2017 #76
    voletl
    voletl
    voletl
    Dec 18, 2014
    652
    200
    New York
    My mistake I interchanged power vent with direct vent.
    When I refer to a water heater that vents out a chimney I call it atmospheric vented
  17. Jan 7, 2017 #77
    KULTULZ
    KULTULZ
    KULTULZ
    Sep 4, 2011
    1,534
    316
    Did you bother to read the TECH ARTICLE I posted above?
    You want SS Double Wall B-Vent.
    Hopefully ( :rolleyes: ), the contractor you choose will be licensed and insured, ethical and pull a permit on the installation.
  18. Jan 9, 2017 #78
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    Mar 9, 2016
    774
    145
    NOKESVILLE, VA
    YES. Bradford RG275H6N
    Deerslayer likes this.
  19. Jan 9, 2017 #79
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    Mar 9, 2016
    774
    145
    NOKESVILLE, VA
    I pray that you have a reputable company to come do this. Direct vent is metal that comes up and out the side of the house. Made with specialized venting that comes with the water heater. Atmospheric venting will get hot and needs to be b-vent style pipe up and out the roof. Power vent and power direct vent uses pvc. It's up to you to read up on the efficiencies.
  20. Jan 9, 2017 #80
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    before you spend money on stainless steal vent pipe
    make sure that is what the manufacture of the water heater you bought requires
    most will require double wall b vent that is NOT stainless.
Share This Page
