S sheesh1982 Member Joined May 10, 2017 Messages 7 Reaction score 0 Location , Dec 26, 2018 #1 Is it OK to connect the washer's drain into the floor drain of the hot water tank?
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,976 Location right here right now, over there later on. Dec 27, 2018 #2 if you have a regular floor drain then no. it has to drain into a hub drain or a floor sink because of the splattering and mess it will make
Diehard In Remembrance Joined Aug 19, 2017 Messages 2,640 Reaction score 471 Location North Reading, Mass. Dec 27, 2018 #3 The hose must also be arranged to prevent siphoning.
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,976 Location right here right now, over there later on. Dec 27, 2018 #4 the hose has to be installed above the water level of the washer if not, the water will drain out of the hose then the hose goes into a stand pipe that can be piped to a floor sink or hub drain
Diehard In Remembrance Joined Aug 19, 2017 Messages 2,640 Reaction score 471 Location North Reading, Mass. Dec 27, 2018 #5 Yup ...that will do it! The OP must understand that the Air Break provided by that standpipe is important.
