tollhaus
Hello, I'm starting the work on my basement bathroom which was roughed in when the home was built in 1988. I bought it a year ago and am going to start finishing the basement. I'm going to hire a plumber to do all the plumbing work, but before I start the framing, I want to figure out what my venting options are.
There are two 2" drain pipes (shower and vanity) and one 4" pipe (toilet) sticking out of the floor. These all go to the pit that is a few feet behind where the wall will be. From what I can tell, there is not a vent line roughed in. Everything is under the slab and the three pipes converge on the 4' pipe into the pit.
The drain line is easy: I plan on using a pump to get to the main drain line which runs along the basement ceiling right next to one of the new bathroom walls.
Can I vent off of the vanity drain for the shower, toilet, and sink? Or will I need to tear up some of the floor to get a vent line in there? Or is there a way to vent off the "pump stack" (not sure what to call it) so I'd basically vent out right before the drains hit the pump? Or can I vent AFTER the pump, on that vertical run up the main drain of the house? (I'm assuming after the pump is a non-starter, but it'd be the easiest.)
Then as for options of where to vent, I could get right next to the radon remediation system and run a pipe right up along the exterior wall next to the chimney. Or, I could easily get a 2" vent into the garage and out a sidewall. Is either of those options ok? Or, I guess I vent to the kitchen vent, wherever that is. (Basement is completely unfinished now, so I can find it.)
Thanks!
Thanks!
