Unfortunately if you can’t get the drain lower, you’ll need to raise the sink.
Looks like you used a 2” wye then a 2x2x1.5 regular tee.
You might could’ve saved some room had you used the fittings there I suggested, but maybe not.
2x2x1.5” wye and a 1.5” Street tee.
You could also use a level and make sure you do not have too much pitch. All you need is 1/4” per ft but it would be fine to have a little less right there, it gets plenty of water volume to clean itself.
Let me know if I can help if you have questions. Your work looks very good.
