- Joined
- Sep 28, 2014
- Messages
- 8,578
- Reaction score
- 2,976
I do not see where it was suggested.
https://www.plumbingforums.com/threads/upgrading-to-1-1-4-main-line.18731/post-143779I do not see where it was suggested.
We would only use atmospheric backflow preventers screwed onto the hydrants if they’re above ground. Then break the set screw off so they can’t be easily removed.All I see is every one is missing the fact the yard hydrants are basically a stop and waste valve
they will require a double ck for a dedicated line or a double ck for each hydrant
1.5 meter is not needed. but. a 5/8'' is not large enough. I believe your water purvayer could swap out the 5/8 for a 7/8'' and yo will be golden. if yo want a 1.5 they are going to hit your pocket book , a new tap would be required and somewhere in the hood of 10k
Where are you getting 300’ of pipe ? His house is Approximately 100’ from the meter.50 psi at the meter 20' of elevation. Gives you 40 psi usable. 300 ft total. The most remote fixtures still need some gpm. The tables and sizing guidelines are based on fixture units. This how I learned in school. I'll go by the IAPMO guidelines. You can go by what you want.
You better get the long form out then because the short form is BS in my opinion for a home.Only when you use the long form equation, do you figure your own expected demand.
To add up fixture units. They aren't figured all at once. Which is what I've tried telling you several times. 40 fixture units is reduced in the table by expected demand for 40 units. It's pretty simple
One 40 gallon hot water heater.I’d like to ask the OP how his home is supplied with hot water. How many water heaters, size and type ?
The code book uses tables to avoid what you're talking about. So some ye-who can't build some piece of crap and say "I think it'll work". The code says he needs an inch and a half meter with an inch and 1/4 supply line. That is if these cobbled-together numbers are what he has in reality.It is simple. You’re using a book rather than everyday experience to determine demand.
I can respect that.
I prefer to use my common sense and experience.
The only reason I would use the long form equation is if he was going to build a header similar to what the other guy was talking about.
