I'd like to stop this flush valve from leaking. Replacing the flapper didn't help. The white plastic appears to be cracked around the middle screw, as you can see in the photo:
I found this similar (but different) flush valve online. No idea if it should be compatible with this one.
What puzzles me is if I unscrew this middle screw, doesn't the metal arch thing fall into the innards of the toilet?
