Altstuder
Hi guys, I've got a small leak welling up out of the slab from a cold supply pipe goes down into the concrete. I'm guessing it's a small pin-hole because water only appears when after running a cold tap. If I run the kitchen tap a very small amount appears. If I run the bathroom tap, much more appears so I figure that's the bathroom supply. Luckily, it's only 4 feet to the bathroom sink. Questions: does that make sense that water only appears if you run the tap? Why doesn't it leak when the tap isn't running? If the water is coming up from the penetration in the concrete wouldn't you think the leak is IN the concrete not below, so the water is forced up instead of down below the slab? There are four supply lines going into the slab and water only comes up from 3rd pipe. Should I try and chip down a ways and see if I can find it? If it's not just below the surface was thinking to try and push 1/2" pex through the 3/4" copper. Any thoughts? thanks
