bkelly
We have a gray water tank and need to pump water out. We need a two float system to implement the concept of run the pump when full and stop when empty. There is a strong preference to not penetrate the walls of the tank so we need two float switches that are completely submersible. The water is to be pumped about 50 feet through ¾ in inch pipe, but less than 5 foot head. I have been advised that a ½ hp motor is preferred. The duty cycle will be well below 5 percent and each run time is expected to be a minute or less.
We have drawn up a one relay connection and can put that in an external box. I suspect someone sells a two float kit of this nature but cannot find it.
My searches have been in vain. Where can I find float/switches that will suffice for this? The submersible pump seems to be easy enough but am happy to hear any advice on that.
Thank you for your time.
