Ceiling in bathroom was leaking and the source was the tub drain in the floor above. Removed tub basket, plumbers putty was disintegrated. Now, the problem is that the shoe underneath is a few millimeters forward (see picture) and when I try to screw the tub basket back on, it gets stuck and I don't want to force as to not strip it. I am also trying to avoid ripping the ceiling in the bathroom below the leak as it is a tile ceiling. There is limited access to the drain from the wall. Can anyone suggest a solution.
I tried to push the drain, from the wall, but it won't budge at all. It could be because there is some cement around it. Maybe use a chisel to break around the cement. Access from the side wall is limited.
