Weidbrewer
Hi! New poster, but I'm hoping someone might be able to help. My house is mid-60s area, one previous owner and as usual, I keep uncovering boneheaded previous repairs. Toilet was leaking and I discovered that the floor was rotten around it. When I pulled up the tiles, I could see that they'd replaced the floor before, but obviously couldn't get the flange off, because there was a hole cut around it.
Unfortunately, I'm in the same boat. I can't find any seam around the top between the flange and the pipe:
...but from underneath, I can see that it is definitely sleeved around the pipe:
What is the proper procedure here? I can install a new one and replace the floor...it'd be annoying to have to call in a plumber just to remove the flange.
Thanks!
Thanks!
