Trouble remove bathroom faucet cardridge metal cover
Dearboy
Nov 24, 2021
Canada
Bathroom faucet is drippin. Its hot water side, I tried to remover the cardridge cover nut but its not moving at all, i think.its stuck. Have try wd40 rust oil, CLR cleaner but its still tight and not move at all. Any idea or tool to open it?thanms
matt.mena
Supporting Member
Feb 12, 2021
215
149
Charlotte
The handle will come off by un screwing the Phillips screw and pulling the handle up. You might have to wiggle and pull if it’s stuck on.
The top chrome hex cartridge cover should spin off the brass body revealing the cartridge inside the brass valve body. Use an adjustable wrench on top to spin the chrome hex cartridge cover.
Hopefully the brass hot cartridge body was installed tight to the porcelain sink. You don’t want to spin the entire brass casing located underneath because it will break the seal of the 3/8” nut connecting the hot water to the faucet (shown second picture) and start a leak.
The tool used on the underside of the sink to tighten the hot and cold cartridge bodies is a basin wrench. It takes a little practice but easy enough. Hopefully you can manage a cartridge replacement all from the top.
Dearboy
Nov 24, 2021
Canada
Thanks for reply, I tried to use adjustable wrench to remove chrome hex cartridge cover but it stuck badly not move at all. I also use hammer to hit the cover but still tightened. I dont know if theres other tools can open hex cover beside adjustable wrench.
cdestuck
Active Member
Jan 10, 2014
40
6
There are other tools Try to get your hands on a 1/2” drive socket set with a appropriate size socket. Will give you more leverage.
Twowaxhack
Professional
Professional
Feb 9, 2021
4,975
2,232
United states
Whatever you do, don’t let the entire valve body turn.
I might would clamp some visegrips under the cabinet top up high on the valve body.
Brace them against the lavatory, the valve body would try to turn counterclockwise. Don’t let that happen.
Grab a cheap set of deep tub sockets and some channelocks. You could even just use channelocks since the chrome finish is already ruined.
Dearboy
Nov 24, 2021
Canada
Okay!thanks for advice
