berkeley.subs
I'm trying to replace a toilet water supply connector. Old connector is grey PVC. Nut is off but grey PVC doesn't pull out of the shutoff valve. Suggestions? A friend suggest using a blow dryer to heat up the area and twist it out, but it's not clear to me whether the gray PCV has a flare that plugs into the shutoff valve. The accumulation of white crap around the valve -- not sure what that is. Your thoughts?
