Aloha Mark
Apparently, the introduction of restricted flow toilets, i.e., watersaving bowls, led to a problem commonly called Toilet Plume. Faster moving water leads to a bunch of mist emerging from the bowl that can contaminate the floor, and even your toothbrush. This video by Our Designer Homes is periodically popping up on youtube.
http://www.youtube.com/watch?v=pcvI44qWIFA
A Brit content provider even did a test using UV dye to track down how the mist propagates through the bathroom.
http://www.youtube.com/watch?v=VTTIU5nzKRQ
My Kohler Cimarron toilet bowl is just one of many offenders. It's a great flushing bowl, but I wonder if it is even possible to design a watersaving bowl to minimize the spraying of tiny droplets? Bad enough that I have to wear a mask to reduce the chances of Coronavirus- do we need to wear masks when using toilets? Frodo, I need you to invent a remote control flusher to take care of the impending health problem. You can get an international patent and make a lot of money. Sounds good?
