Toilet Paper Clogging Up
Discussion in 'Toilets and Sinks' started by fastballbaker, Feb 29, 2012.
  1. Feb 29, 2012 #1
    fastballbaker
    fastballbaker
    fastballbaker
    Feb 29, 2012
    7
    Need Help on This One.
    Every month or so the toilet paper will get clogged in the main drain line. The drain line is about 50ft. long with a 45* turn and then 6ft. from that a 45* T-sweep. It seems that there is a lack of water pressure to force the waste out of the house. Could it be the toilets or could it be the lack of fall on the pipe..Could it have to many turns???
    This is getting to be a pain...Need some help on this one..Thanks
  2. Feb 29, 2012 #2
    johnjh2o
    johnjh2o
    johnjh2o
    Senior Member Professional Lifetime Supporter
    Jul 21, 2011
    3,292
    755
    Melbourne, Florida
    When it get plugged what do you have to do to clear it? Are you just plunging the toilet or are you snaking the line?
    John
  3. Feb 29, 2012 #3
    fastballbaker
    fastballbaker
    fastballbaker
    Feb 29, 2012
    7
    I have to snake the whole line...The plugger want work on this...Thanks
  4. Feb 29, 2012 #4
    johnjh2o
    johnjh2o
    johnjh2o
    Jul 21, 2011
    3,292
    755
    Melbourne, Florida
    It maybe the snake your using is to small to clear the line and all your doing is poking holes in the stoppage that fill up with paper and re-plug. You need a snake with a head that is just little smaller then the pipe.
    John
  5. Mar 1, 2012 #5
    fastballbaker
    fastballbaker
    fastballbaker
    Feb 29, 2012
    7
    I have 48 feet of drain line from my 1st toilet to where it leaves the house, and in that 48ft. i have only a 6 inch drop...Is that about right or not enough...Thanks
  6. Mar 2, 2012 #6
    phishfood
    phishfood
    phishfood
    Moderator Staff Member Professional Supporting Member
    Jan 18, 2010
    5,775
    992
    Orlando, FL
    That is just about right. Code that I use requires 1/8" per foot of fall, so 48' would give you 1/8" per foot.
Draft saved Draft deleted
Share This Page
