Toilet Not Flushing Properly ??
Discussion in 'Toilets and Sinks' started by NorPlan1, Dec 10, 2018.
  1. Dec 10, 2018 #1
    NorPlan1
    NorPlan1
    NorPlan1
    Nov 3, 2018
    5
    Eastern Ontario
    Don't know if there could possibly be an Air Lock or Such in the system.. Have looked for Vent Pipe sticking up thru the Roof (??) Nothing... Have access to the Plumbing from the Basement Ceiling, there is what looks like a small Vent Cap that sticks up T 'd off the toilet drain pipe .. A pail of hot water poured down the toilet has no problem flushing.. Is there another Alternative other than Venting thru the Roof ?? Thoughts & Opinions Appreciated, Cheers Thanks
  2. Dec 10, 2018 #2
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,337
    238
    North Reading, Mass.
    What's the problem?
    So there is no pipe, large or small, sticking up through the roof?
    Why do you mention possible air lock?
    Did you look in attic for AAV'S(Air Admittance Valves)?
    NorPlan1 likes this.
  3. Dec 10, 2018 #3
    voletl
    voletl
    voletl
    Dec 18, 2014
    647
    200
    New York
    If a pail of water manully dumped in the toilet goes down just fine then it is the toilet itself that is the problem. Not venting or any of the drain pipes
    GReynolds929 and NorPlan1 like this.
  4. Dec 10, 2018 #4
    NorPlan1
    NorPlan1
    NorPlan1
    Nov 3, 2018
    5
    Eastern Ontario
    (Nothing Sticking Up Against Wall coming up From The Wall)
  5. Dec 10, 2018 #5
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,337
    238
    Diehard said:
    What's the problem?:confused:
    (Nope)
    (Just The Way It's Flushing):confused:
    Sorry I don't follow this statement. Are you referring to the absence of pipes coming up from the toilet wall?
    So the problem is, "Just the way it's Flushing"??? And just how it flushing?:confused:
  6. Dec 10, 2018 #6
    NorPlan1
    NorPlan1
    NorPlan1
    Nov 3, 2018
    5
    Eastern Ontario
    There is no AAV's and Vent Pipe poking thru the Roof... It just doesn't have the Umph as it should , taking 2 / 3 Flushes to get rid of the Hershey Bars... Is All..
  7. Dec 10, 2018 #7
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,337
    238
    I get the picture now.
    Since you seem to feel that, "A pail of hot water poured down the toilet has no problem flushing.", I would lift the lid off the toilet tank and first check that it's full up to the recommended level. Maybe like 1/2" below the overflow level. Assuming that's okay, I would try flushing while the lid is still removed, and observe for anything unusual. For example, the entire tank should empty rather quickly and completely, before the flapper closes.
  8. Dec 10, 2018 #8
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,277
    191
    Boston, Massachusetts
    sounds like it could be :
    to much slack in the flapper chain....
    the wrong flapper
    there are other things that you can do but start simple.....
  9. Dec 10, 2018 #9
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,277
    191
    take some pics of the inside of the toiletand see if you can find a name.....should be right behind were the toilet seat tightens to the bowl
  10. Dec 13, 2018 #10
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    not a Junior Member anymore! Sponsor
    Mar 9, 2016
    774
    144
    NOKESVILLE, VA
    could be the holes are clogged up under the rim.
  11. Dec 13, 2018 #11
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,337
    238
    Yeah that crossed my mind, particularly after seeing you had mention that on another post. That never crossed my mind before then.
    SHEPLMBR likes this.
Share This Page
