Toilet leaking
Discussion in 'General Plumbing Help' started by Thumbs, Mar 18, 2018.
  1. Mar 18, 2018 #1
    Thumbs
    Thumbs
    Thumbs
    Mar 15, 2016
    I have water continuing to drain into the bowl after the tank has refilled. I don't hear or see anything when I remove the tank lid, float is in upright position, no change when if I manually apply pressure to the flapper and water level appears to be constant. Just got notice from water bureau about higher than normal use. Any suggestions appreciated.
  2. Mar 18, 2018 #2
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    294
    41
    Boston, Massachusetts
    put some dye in the tank see were it goes
    just a guess it might be leaking by so slow that your not near it or home or sleeping???????
  3. Mar 22, 2018 #3
    Thumbs
    Thumbs
    Thumbs
    Mar 15, 2016
    Okay, I have confirmed that my water leak is because of the toilet. Based on the water bill, 22 gals. of water is running thru the toilet an hour. The toilet has Korky hardware. There's a little ripple in the bowl and I never hear water running to refill the tank. Evidently this has been going on for months. Can a professional please explain why I never hear the tank refill?
  4. Mar 23, 2018 #4
    havasu
    havasu
    havasu
    Jan 6, 2010
    8,880
    1,157
    Southern California,
    Lots of reasons. Water height adjusted too high? Flapper has sediment between it and the porcelain seal, causing water to leak through. A crack in the porcelain. Chain incorrectly adjusted.
    If you can get a picture of the inside of the tank, it may tell us alot.
    With this being said, you would hear water trickling at all times since that is about 1/2 gallon of water a minute.
  5. Mar 24, 2018 #5
    Rickyman
    Rickyman
    Rickyman
    Feb 5, 2018
    20
    The fill valve is not shutting off all the way and water is going down the overflow tube.
  6. Mar 24, 2018 #6
    havasu
    havasu
    havasu
    Jan 6, 2010
    8,880
    1,157
    Spend $11, and purchase a new valve.
  7. Mar 24, 2018 #7
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    265
    50
    Mansfield,, Ohio
    If your not seeing any water running when you take off the lid then I would do as Havasu suggested and replace the flapper at the bottom of the tank. Take a cloth or something and clean the seat that the flapper sets on. If its not a flapper type seal then show us what it is.
  8. Mar 26, 2018 #8
    Thumbs
    Thumbs
    Thumbs
    Mar 15, 2016
    Thanks everyone for the suggestions. Turns out the flow valve was bad. Damn $10 part cost me a $1200 water bill.
  9. Mar 26, 2018 #9
    havasu
    havasu
    havasu
    Jan 6, 2010
    8,880
    1,157
    As a homeowner, you need to be a great listener to any strange sounds inside your house. If you heard this water running, you could have saved yourself some money. As a last ditch effort, you could try to go to your water company with the bad valve and see if they could adjust your water bill. Some will do it, others won't. I would also demand that they replace your water meter, because that seems like an awful lot of water used with one leaky toilet.
Share This Page
