Quantcast
Toilet leak
BPL77
Feb 22, 2021
6
Phoenix, NY
I have a toilet that has a constant leak straight into the pipes, which has caused it to consistently run. In trying to diagnose the problem, I have replaced the guts of the tank, including the entirety of the fill and flush valves. In replacing the flush valve (and gasket), I assumed my problems to be solved. Upon trying to fill the tank, I heard the leaking again. I haven't called a plumber yet, as I wanted to try to figure this issue out myself. Any ideas are welcome! Thank you in advance.
sarg
Oct 26, 2020
176
92
Northeast
Either the flush valve is not making a seal & leaking .... or the small diameter fill tube that goes from the fill valve to the overflow is placed too far down the overflow tube.
Pictures are a great help.
BPL77
Feb 22, 2021
6
Phoenix, NY
Did you replace the flapper, you said gasket so i wasnt sure if you meant flapper or fill valve gasket
All of the above actually...lol. I originally changed out the fill valve and the flapper with that. When that didn't work, I changed out the flush valve, which came with its own flapper.
BPL77
Feb 22, 2021
6
Phoenix, NY
Twowaxhack
Feb 9, 2021
743
240
United states
Those adjustable flushvalves suck. Has an oring in there to leak.
Replace the flushvalve.
Get a plain Jane white flushvalve. Use that same flapper.
sarg
Oct 26, 2020
176
92
Northeast
The adjustable overflow tube certainly presents another possibility. If it leaked it would cause the problems described.
BPL77
Feb 22, 2021
6
Phoenix, NY
There was a plain white one in before I replaced it with this one. Also, when I went to refill the tank, it never even got half-way full before leaking. I don't know if that changes your assessment...
Twowaxhack
Feb 9, 2021
743
240
United states
Not at all. I use the plain white ones. Various manufacturers.
sarg
Oct 26, 2020
176
92
Northeast
Stop back & let us know if that was the solution. ( Wonder if you lost the O-ring during installation )
sarg
Oct 26, 2020
176
92
Northeast
Understood ...... I was looking at those kits with the adjustable height overflow........ seems they all make a version ....... and now I appreciate this thread.
