Toilet Flange Too Tight to fit in 4” drain
Benva
Jan 4, 2021
6
VA
Help please! I am getting ready to install Oatey quick set toilet flange, and the trouble is that the flange won’t dry fit. After I deburred and sanded inside of the 4 inch drain pipe, I am only able to push in 1/2 Now.
I have done quite bit plumbing work in my basement, never seen something like this. It appears the 4 inch drain pipe doesn’t have a smooth inner surface. I am not sure if apply PVC glue will let me to push the flange all the way in. Please advise. Thank you.
Benva
Jan 4, 2021
6
VA
It should push on all the way once you clean and glue it.
thanks. As plan B, just in case it won’t go all the way in, should I immediately pull the flange out and wipe the PVC glue clean?
