Toilet Drain
Discussion in 'Drain and Sewer Cleaning' started by WP50, May 20, 2019.
  1. May 20, 2019 #1
    WP50
    WP50
    WP50
    May 20, 2019
    W. Texas
    New to the place so Hello from W. Texas.
    Have removed all the cast iron drain pipe from our home. 1926 model.
    My question is the pipe under the toilet I'm told is a closet bend ???? .
    Sites seem to bring up cast iron closet bend but am going back with PVC.
    What should I look for to replace the closet bend in PVC ??
    Would a 90 sweep or 90 el (I think it's called) do the job?
    Distance from center of flange to drain stack is no more than 2 feet.
    Terminology of parts and such gets me in alot of trouble at times.
    Thought I d ask.
    Thanks for time Respects WP50 David
  2. May 21, 2019 #2
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,311
    use a 4x3 90
    with 4'' up through the floor
    then cut the 4'' pipe off flush with the finished floor
    install a 4x3 closet collar INTO the 4'' pipe
    secure to the floor using brass screws
    DO NOT use steel screws
    the acid in human pee pee will eat the steel screws up but will not eat the brass
    I am showing ABS and PVC it is just the stock image i have, use the same type of pipe do
    not mix match
  3. May 22, 2019 #3
    WP50
    WP50
    WP50
    May 20, 2019
    W. Texas
    Do appreciate the info. One more question please.
    The drain stack is 4 in PVC .
    "install a 4x3 closet collar INTO the 4'' pipe"
    Are you saying use 4x3 collar into the drain stack ??
    Thank you again
  4. May 23, 2019 #4
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,311
    you asked about replacing a 90 degree fitting under a toilet.
    i answered about that
    are you now asking about tieing that toilet into a drain stack
    or connecting it to a drain line?
Share This Page
