Toilet defect?
Hamberg
Active Member
Jan 12, 2019
29
Horsham PA
Can't imagine how this would happen but I have basement toilet (feeds to a grinder pump) that has started draining slowly and most of the time does not completely flush on the first time.
There is a bar sink and dishwasher feeding the same pump and neither have drainage problems.
The water level rises and (by my interpretation) seems to drain slowly - not sure how that is regulated.
Tried plunging numerous times but it does not help or make better.
Any suggestions?
FishScreener
Aug 23, 2018
328
92
83467
Is the flush tank filling correctly? A low volume of water in the toilet tank, will cause the problem you are describing.
My guess is you have a slow leak in the flapper valve, and if it sits for a while it bleeds down, resulting in a low water volume in the toilet tank, which is too low to actually flush, and when you flush the second time you are getting a full volume flush, and it works.
Also an improperly set flapper valve can cause the same issue by closing too soon.
Hamberg
Active Member
Jan 12, 2019
29
Horsham PA
Yes tank is full, and flapper was replaced (not leaking). Also verified it is not closing too soon.
Hamberg
Active Member
Jan 12, 2019
29
Horsham PA
If you pour 3 gallons down the toilet will it flush normal or will it back up
Hey CT - yes, it flushes and drains normally (if I pour a 2/3rds full, 5 gallon bucket of water)! However, once I try and flush (after) it only half drains.
Jeff Handy
Jul 5, 2019
1,662
288
Chicago suburbs
There is probably a partial clog in the drain line.
That can cause slow flushing, and can cause the water in the bowl to be slowly sucked almost dry.
CT18
Apr 30, 2014
616
152
Bloomfield Hills, Michigan
How old is the toilet. Over time the jets around the rim clog and do not allow the tank to empty fast enough for a proper flush
Hamberg
Active Member
Jan 12, 2019
29
Horsham PA
Interesting!? Something I didn't realize could happen! Anyway to confirm this? (short of replacing)
Jeff Handy
Jul 5, 2019
1,662
288
Chicago suburbs
You can take a wire coat hanger, cut it open and use the stiff wire end as a reaming tool.
Usually giving the wire end a slight curve will help it slip into the clogged rim jets.
Poke through the crusty holes one at a time, and twist the wire around to break up some of the mineral build up.
Hamberg
Active Member
Jan 12, 2019
29
Horsham PA
Did as instructed and it did not help. (Jets were not significantly clogged)
So if I dump a 3-gallon bucket down, it works (flushes) correctly. But, if I do a normal flush (including holding the handle down and letting the tank drain) it does not (only half drains)!?
What am I missing??
Jeff Handy
Jul 5, 2019
1,662
288
Chicago suburbs
I still think your toilet drain is probably half clogged.
Go buy a toilet auger and use it to clear the toilet trap and first few feet of the drain.
You can get a toilet auger that will go in six feet.
Or pull the toilet and snake the drain all the way to the sewage pump pit.
Or snake the drain from the pit all the way to the toilet, so you don’t have to pull the toilet.
Just don’t go into the toilet, you can take care of that end with the toilet auger.
6 ft. K-6 DH Toilet Auger with Drop Head
https://www.homedepot.com/p/202826734
TomFOhio
Professional
Professional
Jan 20, 2018
1,091
228
Mansfield,, Ohio
I think you need a need toilet. If it flushes with the bucket of water its probably not plugged. The toilet must have
lime buildup and not letting the water from the tank to the bowl work correctly. Just my opinion.
Hamberg
Active Member
Jan 12, 2019
29
Horsham PA
Got auger 6' version - augered (or whatever you'd call it :O)) all the way down and no help.
Same problem - leaning towards just replacing...
Hamberg
Active Member
Jan 12, 2019
29
Horsham PA
Tom - you beat me to it! Next step is to just replace the old one.
