Toilet bowl keeps filling up!!! UGH...
Discussion in 'Toilets and Sinks' started by Song Pak, Dec 2, 2018.
  1. Dec 2, 2018 #1
    Song Pak
    Song Pak
    Song Pak
    Dec 2, 2018
    Richmond, Va
    Hello ALL,
    So I replaced the flush valve and fill valve on my toilet and went to flush and the water in the bowl does not FLUSH and just keeps filling.. I have to pull the toilet handle up to stop from filling the bowl.. what did I do wrong!?!?! this was an easy replacement and Im certain I did everything correctly. Please help! thank you in advance...
    Song Pak
  2. Dec 3, 2018 #2
    jeffmattero76
    jeffmattero76
    jeffmattero76
    Nov 3, 2017
    313
    64
    Did you try to plunge the toilet?
    The flush valve and fill valve have nothing to do with the ability 9f the bowl to empty, unless you dropped a part into the bowl and clogged it.
    Mikey likes this.
  3. Dec 3, 2018 #3
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    not a Junior Member anymore! Sponsor
    Mar 9, 2016
    761
    141
    NOKESVILLE, VA
    Take a wire coat hanger to the holes up under rim.
  4. Dec 3, 2018 #4
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,195
    1,268
    Southern California,
    Sound like the flush valve was installed incorrectly. Take a picture of what's going on and we can help you further.
    GReynolds929 likes this.
  5. Dec 4, 2018 #5
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,016
    146
    Boston, Massachusetts
    sounds like there is not enough slack on the flapper chain.....is this a new flapper??????
  6. Dec 4, 2018 #6
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,016
    146
    so I just re read your post is the water going over the overflow tube??????
  7. Dec 4, 2018 #7
    jeffmattero76
    jeffmattero76
    jeffmattero76
    Nov 3, 2017
    313
    64
    What am I missing??? What do any of these replies have to do with the bowl filling up, rather than emptying?
    Mikey and Diehard like this.
  8. Dec 4, 2018 #8
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,005
    196
    North reading, Mass.
    Yeah, that's the toughest part of these questions sometimes. You have to read them extremely carefully and if there is any doubt, have them clarify. :confused:
    I read it the way you did. The water is flowing from the tank to the bowl but not leaving the bowl.
    LMAO
    Mikey likes this.
  9. Dec 4, 2018 #9
    Mr_David
    Mr_David
    Mr_David
    Easily Amused Professional
    Jan 12, 2010
    4,171
    1,058
    Santee,Ca,
    That's a tough one to read. Presuming the tank filled before he flushed it, or did it fill at all.
    Wrong flapper maybe not closing.
    Then pulling the handle up to stop filling the bowl. ????? How's that for added confusion.
  10. Dec 4, 2018 #10
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,195
    1,268
    Without pics, I can imaging the flush valve is not installed correctly, and allowed to float up to shut off the water, allowing the fill tube to overflow into the bowl. Just a guess based on OP's description.
  11. Dec 4, 2018 #11
    jeffmattero76
    jeffmattero76
    jeffmattero76
    Nov 3, 2017
    313
    64
    Sorry, but I don't understand. Even if the water is constantly going down the fill tube, how would that cause the bowl to fill up rather than flushing?
    Diehard likes this.
  12. Dec 5, 2018 #12
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,195
    1,268
    If your bowl is not flushing down the water, you have a clog in the drain line.
  13. Dec 19, 2018 #13
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    770
    174
    Mansfield,, Ohio
    If you had to pull the handle up to stop the water then the flush valve is not setting back down on the seat after flushing.
  14. Jan 2, 2019 #14
    AlanE
    AlanE
    AlanE
    Aug 4, 2012
    On a standard toilet, the handle only controls the flapper. Given what the OP said about raising the handle to stop the water running into the bowl, I'll also go with chain doesn't have enough slack to allow the flapper to fully seat.
    [​IMG]
  15. Jan 2, 2019 #15
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,005
    196
    A month has gone by and never another word from the OP. Appears that we'll never know what his/her problem was. Hopefully they didn't get flushed down the toilet.:p
    Zanne and havasu like this.
Share This Page
