To add a back water valve, or not to add a backwater valve...
Discussion in 'General Plumbing Help' started by mikeyb7691, Mar 18, 2018.
  1. Mar 18, 2018 #1
    mikeyb7691
    mikeyb7691
    mikeyb7691
    Mar 14, 2018
    13
    Hello,
    My question is should i add a backwater valve to my main line?
    Living in an old house on a level road in the city if Toronto.
    $1600 plus permit and tax plus floor tile repair -$1250 rebate.
    Sounds like a no brainer, but could it cause more trouble to
    maintain? Say sewage backing up if i forget to clean
    it out.
    Thanks in advance!
  2. Mar 18, 2018 #2
    justin_dewan90
    justin_dewan90
    justin_dewan90
    Nov 23, 2017
    269
    28
    Reason for the valve is if the city main backs up. It will flood your house if you are the lowest on the line. That's the only reason for it. Valve will need to be accessible for maintenance. That "flapper" could get dislodged and create issue. That why I say leave it open. Have you had issues with the city main backing up in your area?
  3. Mar 18, 2018 #3
    mikeyb7691
    mikeyb7691
    mikeyb7691
    Mar 14, 2018
    13
    Hey Justin,
    No, i never have had any issues with backup.
    My reasons are just in case, given the more
    intense episodes or rain which happen.
    I thought the flap stays down in its neutral
    position.
    Thanks,
  4. Mar 18, 2018 #4
    justin_dewan90
    justin_dewan90
    justin_dewan90
    Nov 23, 2017
    269
    28
    The valve would be downstream of where everything in your house ties in. So it would open for when your waste water goes through it or wherever it is decided to be put. See them on 4in sewer pipe and do see them on 2in drain lines. Depending on where it is required to go. Now, if it is on a 2in drain line and you have a bathroom on a Wye. You will still have potential for sewer water to come up there. If it is on the 4in trunk line going out of the house. You won't have that issue.
  5. Mar 18, 2018 #5
    mikeyb7691
    mikeyb7691
    mikeyb7691
    Mar 14, 2018
    13
    Yeah it would most definitely be on the main 4” line
    going outside of the house near the foundation wall.
  6. Mar 18, 2018 #6
    ExtraMilePlumbing
    ExtraMilePlumbing
    ExtraMilePlumbing
    Aug 21, 2014
    438
    68
    If you’re on level ground, I would just install a clean out with a pop up cap
  7. Mar 18, 2018 #7
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    583
    124
    Mansfield,, Ohio
    They make back water valves for outside of the house. It has to be dug up but you don't have to break up the floor or tile.
  8. Mar 18, 2018 #8
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    568
    76
    Boston, Massachusetts
    i just repiped my brother inlaws basement adding 2 baths and a back water valve we also added a cleanoutoutside well the main in the street backed up
    i didn't flood his house.....if you have any fixtures in the basement you will flood just imagine the clean up and insurance hassle.....
  9. Mar 18, 2018 #9
    justin_dewan90
    justin_dewan90
    justin_dewan90
    Nov 23, 2017
    269
    28
    Like geof said, it does make sense to have a backwater valve. But you need to make it accessible wherever you put it. Have ran across ones outside 5ft deep that were inaccessible and the problem was at the valve. Whatever way you go, leave it accessible. It will need maintenance on it.
  10. Mar 19, 2018 #10
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    583
    124
    Mansfield,, Ohio
    To the original poster, if needed, you can put it inside and make it accessible. You have the option to put it outside and purchase one to make it accessible, they make both. If you ever had any water back up into your house this is something that you would want to look into. Also they are like a car, if you want it to work properly you have maintain it.
  11. Mar 19, 2018 #11
    mikeyb7691
    mikeyb7691
    mikeyb7691
    Mar 14, 2018
    13
    Thanks Tom, no i haven't had water back up into my house. I live on a level road if that makes a difference. Will the backwater valve be as deep as the main line, so 2-3 feet deep? The plumber says thats accessible but it sounds a bit tricky to reach.
  12. Mar 19, 2018 #12
    mikeyb7691
    mikeyb7691
    mikeyb7691
    Mar 14, 2018
    13
    Yeah exactly, I don't think mine is 5 feet deep but might be 2-3 feet deep. I could probably access it at 2 feet but 3 feet? Hard to say.
  13. Mar 19, 2018 #13
    mikeyb7691
    mikeyb7691
    mikeyb7691
    Mar 14, 2018
    13
    Thanks Geofd!
  14. Mar 19, 2018 #14
    mikeyb7691
    mikeyb7691
    mikeyb7691
    Mar 14, 2018
    13
    Thanks ExtramilePlumbing, I do have a clean out installed already inside the house and outside. I read online that recommends you have a clean out valve if your lowest drains are not 2 feet or more higher than the city sewers. My basement drains are about 2f eet lower than the outside sewers.
Share This Page
