I've been using the shower with the typical pull up/gravity return diverter that works for about a year and then stops working as mineral deposits inevitably build up and even using diluted CLR type lime removers stop working and you have to manually push the diverter down to avoid being shocked senseless the next time you get in the tub and turn on the water to a very cold and unexpected shower. I have also used a better one, although still not happy, that you pull down on a section of the spout at the output to divert to the shower that uses a spring loaded mechanism to return to the original tube spout water output. That solution works better but you still have to be vigilant and use silicone grease from time to time to keep that diverter happy.
Does anyone make a replacement wall mounted on/off/diverter assembly that uses a positive, manually operated valve to control the direction of water flow to either the spout or the shower head because I certainly can't find a manufacturer that makes one.
Thanks in advance!
Thanks in advance!
