Three Handle Shower Faucet, No Hot Water
frizzaroni
Sep 17, 2018
10
Colorado
I have a faucet in a tub/shower combo that has a handle for hot, handle for cold and handle to turn on the faucet and shower We had the tub replaced and shower tiled and since then the hot water from the faucet will not work. It gets barely like warm. There are no issues with the hot water anywhere else in the house. Any suggestions on how to fix this?
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,642
501
Boston, Massachusetts
was this a new install???????I mean the shower valve???????
the handle that's not hot or cold is that how you shut off the faucet/shower?????? or do you shut off the hot and cold handles
frizzaroni
Sep 17, 2018
10
Colorado
You turn the water on or off with the middle handle. The hot and cold are just to adjust the temperature.
frizzaroni
Sep 17, 2018
10
Colorado
frizzaroni
Sep 17, 2018
10
Colorado
With the middle handle. Left is hot, right is cold and the middle is to turn on the faucet or the shower head.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,642
501
try shutting off the hot and cold using it like that see if the temp changes and only use the middle one for the diverter.....
frizzaroni
Sep 17, 2018
10
Colorado
When only using the middle, hot and cold both off, the water remains cold.
When turning on cold, it gets colder. When turning on hot, nothing happens, it remains cold.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,642
501
do you know what brand it is.....can you see or feel piping feeding the valve
frizzaroni
Sep 17, 2018
10
Colorado
I believe it is Delta brand. Yes, I can see a little piping and when the hot water is on the piping barely feels warm on the hot side. You can see the set up here. The piping is the same color as the handle.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,642
501
does that also divert the water from the spout to the shower head????
if mr david is right the hot stem is stuckso its not allowing the water to mix properly.....I have seen this in single handle pressure blanacing valves
remove the stems soak in vinegar and reinstall
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,642
501
I would contact delta.....they may have delt with this symptom and can give you and awnser right away
frizzaroni
Sep 17, 2018
10
Colorado
Which part is the stem? I took off the handle today and it was just that, the handle. The piping portion is in the wall through the tile.
pasadena_commut
Sep 10, 2016
117
22
Generally a stem is extracted this way:
0. Turn off the water!!!! If it is just the hot side you are working on that can usually be turned off separately at the hot water heater.
1. Take off the handle.
2. There is a sort of metal ring around the post that went into the handle. It unscrews, but you may need a strap wrench to get it moving. Don't use a plumbing wrench - even if you tape that ring really well the wrench's teeth will rip up the finish.
3. After the ring is off the flat plate like piece (sconce?) which is against the wall should come off. These are not threaded onto anything, they are held in place by the ring.
4. Now you should see a big nut which holds the stem in place. Remove the nut with the appropriate plumber's socket.
5. Pull out the stem.
If your house is old and has rusty pipes a big slug of rust can sometimes build up just upstream of the hot or cold valve resulting in a low flow condition on one side like what you describe. If that is what it is, after the stem is out turn the water on briefly and it will probably blow out the plug of rust.
Jamesplumbing06
Feb 24, 2016
605
124
Wow. Ok delta parts are like $12. Rebuild the whole thing. Prolly could’ve been done by now. Good luck and god bless.
