Michael Davidson
Had been getting air in the line and now lost all water together we have turned off the water pump and the hot water heater at their breakers. We found the problem was a cracked coupler just after the check valve. Once we stated taking it apart we found a lot more problems all the way back to the pipe that come out of the ground were they drilled. The pipe that comes out of the ground were they drilled has an elbow on it that had a converter peace that went from galvanized pipe to PVC when we unscrewed the converter peace we found that the treads had broke off inside the elbow. For a temporary fix we were thinking of cutting off just down past the elbow and for now just to get water back till we can get a plumper using a radiator hose from a car with hose clamps and convert that over to PVC. Is this something that will work or would there be to much suction coming out of the well to the pump and possible colaps the water house ? If so is there a better temp fix for now?
