Toxarch
Active Member
Disclaimer: The house and well are less than 5 years old. There was a hard freeze in February, some frozen pipes in the house but no burst pipes. I am not a plumber. Sorry for the large pictures.
We have had a lot of rain lately so I turned off the sprinklers. I run the sprinklers late at night so that they are done running by morning and I have good pressure for the showers. This problem seems to have started within the last 2 weeks since I shut the sprinklers off. I did shut off the valve to the sprinkler line while troubleshooting this. I also flipped the well breaker off and back on.
I have noticed a lot of low pressure when running the faucets. You really notice it when 2 things are running like the toilet tank filling back up and the faucet running.
I believe the pressure switch is a Square D 30/50.
I checked the meter on the water softener and it shows that there is not any water flowing inside the house.
Here is well power box incase you need to know that:
Here is the tank pressure with everything off. This is normally close to 60psi.
This is my pressure when a faucet is open:
Pulled the cover off the switch, disengaged it with the lever, and tested the voltage across the wires.
1-3 was 120v
2-4 was 120v
1-4 was 240v
2-3 was 0v
It would not disengage the contacts without flipping the lever up.
I am afraid that since it is not running the well pump when the contacts are closed, that it is a bad well pump. I am hoping not. I am hoping that it is just the switch since that is a $30 part. But like I said, I am not a plumber so I am here to see if you have any ideas or things I should try. I think the well is somewhere around 340 feet deep and I would assume that it does not flow naturally without a pump.
Thoughts? Anything I should try? Any more info you need?
1-3 was 120v
2-4 was 120v
1-4 was 240v
2-3 was 0v
