sundug
After removing and rebuilding my solar hot water collector I noticed the swing check valve was allowing reverse flow. It's a typical brass swing check like this- Shop AMERICAN VALVE 3/4" Brass Check Valve at Lowes.com
It is installed in a horizontal pipe. I am wanting to install a vacation bypass valve to go around another check valve. Because the present check valve is in a difficult place to get to, and I don't have the room there to bypass it, I was just going to disable it. However, all the rest of my plumbing is on angle and I see spring check valves that claim they can be installed in horizontal or vertical positions. I assume that means they can also be installed on a 45 degree angle. True? Another concern is my closed loop is driven by a 21-year-old 10 watt photovoltaic panel, and I'm wondering how much back pressure a spring check will provide or a swing check on a 45 degree angle. Does anyone have any experience in this area? Thanks, Doug
