Hello, I have a general knowledge question relating to my basement sump.
I was having a little problem with the pump running after it drained the pit, which i figured was a problem with the float arm (zoeller 53). Thinking I would need to replace the pump soon, I unplugged it, to see about how long it would take to fill up. Now the pump had been running pretty regularly ,pumping out about 5 gals every couple minutes( I timed it). When I shut the pump down the water level rose to the height of the drain pipe and stopped. I have been watching it for a couple hours and no more water has come in.
So whats happening? Is the water is just staying in the drain tile, or is water building up around the foundation, I assume that would be bad. Why was so much water draining in before? My basement is pretty standard about 7 feet below ground. Is there some simple explanation that I'm just not seeing. I know water does rise above this level at times, I had some water in the basement a few years ago, when the pump went out.
thanks.
thanks.
