I want to know if it is feasible to have my sump pump drain water directed to an above ground storage tank of 500 to 1000 gallons capacity. If it can be done, what would I require to get the water into the tank?
At present my sump pump drains to the edge of my property, but it is saturating both some of my property and some of my neighbor's. They want this issue resolved more than I do. Also, I assume I am constantly recycling the drained water back to the sump pump. I live in the country so no sewer or storm drainage is available. There is no available ditch for disposal. The water table level is very high. I have clay soil preventing absorption. I cannot use the septic tank as the drain field already is often saturated due to the above conditions and heavy washing machine usage.
If I can go the storage tank route, I have a friend who could empty it as needed. I realize I most likely could not use that system in winter due to freezing. I do not want to put in a similar size tank underground but would consider if necessary and doable.
Let me know if any other info is wanted. Thank you for any advice you may be able to provide.
