Quantcast
Sump pump switch short lifespan.
acaruso1977
Sep 15, 2020
Macomb, MI
My home is only 8 years old and I am on my third sump pump. Every time it is the switch that is going bad. I'm only getting a couple of years out of every product I buy. No matter the horsepower rating the switch still goes bad. My basement does collect more water then normal. I need advice on a product that has a switch capable of heavy use such as something that you would need if you were in a floodplain?
gagecalman
Nov 11, 2016
82
16
Baltimore, MD
I've had excellent results using a HydroCheck HC6000 "Hi-Lo Sump Pump Controller" with a manual pump. No floats to hang up and no mechanical switches to go bad. There are two sensors so you can set the on/off height where it works best for your situation and to reduce short cycling.
I've installed the HydroCheck HC6000 in about 8 systems for friends and family. Been flawless for 10+ years.
https://www.amazon.com/gp/product/B006AU4L4U/ref=ox_sc_saved_title_8?smid=A383041HQ944EK&psc=1
