Our sump pump will run fine for a few minutes then you can hear it running but no water is moving. Shortly after that the alarm comes on and the backup pump engages. If I unplug the pump and plug it back in then it engages again and pumps water fine for a few minutes.
From my limited research it seems like an air lock. There is a vent hole already drilled in the discharge pipe and it is not clogged. What else could be causing my issue.
