Hello I'm looking for info with regard to my submersible pump and water supply. I had a submersible pump installed about a year ago.
I had some issues with the pump floating up to surface.
I suspected that someone may have pulled in up from the bottom, which is about 5 to 6 feet deep. I have a bouy attachd to mark its location.
I've had trouble on a couple of occasions in the past with this happening.
I originally had this submersible pump installed because the old jet pump was giving me trouble.
I had two plumbers tell me the submersible was the way to go.
So I paid and had it installed.
I sank a pump and line down with enough weight that it would not surface. Shortly after this, I lost pressure, called plumber and he came out and changed the filters. Apparently they were clogged and he changed to a lighter fiber ? Apparently more friendly for over the course of the winter.
Our lakes freeze over the winter.
This is my fulltime home.
Any thoughts , feed back appreciated.
Thanks
Lakefront
Thanks
Lakefront
