jpokerwinski
i amusing pen tubing. How far beyond the drywall should pex tubing extend before adding supply shut off
I saw this and I’m not sure how to use these. I was going to extend the pex out about 5 or so ago inches then use a shark bite 1/4 turn valve.This is what I use. You might want to consider it. Then use a 5/8" X 3/8" compression valveView attachment 19855
You have a picture of what you mean?Should end in the wall, then mounted and secured within wall and stubbed out with shut off.
