Strange tub faucet handle
Mic81784
Jul 1, 2020
7
44035
Hello!
Just moved in to new house recently. The tub faucet isn't like any other I've encountered. When the water is off, the handle points up at the ceiling. If I turn it a little to the right, the water is super hot. All the way 180 degrees to the right and I get mildly hot water. If I turn to the left, it is all cold. Is this easily replaceable with a normal handle that I can just turn all the way around? Do I need to post pictures? First post on the forums here, thanks.
Mic81784
Jul 1, 2020
7
44035
I should mention it does not go all the way around. It is either left or right for 180 degrees
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,000
296
Boston, Massachusetts
There maybe an Allen screw somewhere on that handle were that yellow circle is, that cap may expose a screw
Mic81784
Jul 1, 2020
7
44035
Is it just as simple as replacing with a new handle that is to my liking? I wasn't sure if it needed something proprietary to this faucet.
havasu
Administrator
Staff member
Admin
Jan 5, 2010
9,633
1,414
Southern California,
You should be able to unscrew and rotate that handle so it points down. That way, it is less confusing
Mic81784
Jul 1, 2020
7
44035
Our issue is that it is only hot, warm or ice cold. A lukewarm shower would be nice in the summer. There is no way to achieve it right now.
Tech
Active Member
Nov 19, 2011
26
Hello!
its upside down. universally it's cold on the right hot on the left. Perhaps the whole faucet was installed upside down.
Riickk
Nov 14, 2019
150
38
Delaware
Another of the Moens with the worn-out valve that mixes hot/cold before you want it to?
Jeff Handy
Jul 5, 2019
2,006
372
Chicago suburbs
Looks like an amateur sloppy job of installation.
The shower valve should be much higher on the wall, yours is actually touching the tub spout.
So who knows what other goofs have been made in that installation?
Jeff Handy
Jul 5, 2019
2,006
372
Chicago suburbs
The handle was probably mounted upside down because it was too low and hard to reach if mounted correctly.
It also might have been close to hitting the tub spout.
Mic81784
Jul 1, 2020
7
44035
I should also note the home is 100 years old. So I'm assuming they were not up to code lol
Riickk
Nov 14, 2019
150
38
Delaware
It looked to me that if that handle was mounted long end down, it would hit the tub spout. I remember reading the instructions on first single lever tub-shower I installed, they specified a certain minimum distance between the tub spout & the handle, accordingly so the diverter would work right.
I wonder if that's an issue the OP is dealing with.
TomFOhio
Professional
Professional
Jan 20, 2018
1,096
230
Mansfield,, Ohio
I agree with Jeff that the handle was hitting the spout. Try reversing it and see if it hits.
House Doc
"If it's broken we fix it
Jan 5, 2010
122
42
Southern Cal..by way of Chicago area
The cartridge needs to be turned 180 degrees. Reinstall handle pointing down (no, it will not hit the spout).
Turning counter-clockwise- cold 90 degrees, to warm180 degrees, to hot 270 degrees.
Direct from Moen tech support.
