Herb
I have an 12 yr old Moen 7730 kitchen faucet with sprayer. The spout had seized up and could not be removed, so I purchased a new spout assembly, spout body, and diverter from Moen. Once everything was connected, I found that the water ran on for several seconds after the tap was shut off. However the water stops immediately when turning the tap off with the spray running, suggesting the tap and cartridge are OK. I contacted Moen and they sent me a new diverter, which made no difference when installed. They have no other suggestions to solve my problem.
The only difference I can see with this new setup vs. the old one is the use of quick-connect fittings for the sprayer hose. There are no visible leaks, and the connection seems tight enough - but could this be part of the problem?
Any suggestions would be most welcome.
