Just moved into our new home, upgrading old appliances. I have installed dishwashers before, in common situations.
This time it's a little different. The previous installation looks like it was about 15 yrs ago was a Bosch dishwasher, which doesn't seem to have a way to detach its drain hose. I discovered last night that the drain hose and water source are routed through a hole cut in the tile floor. Under the sink, a black (non-corrugated) drain tube comes up through a hole and attaches to the drain- so the connection between the two hoses is hidden beneath the floor somewhere. I haven't found access to it anywhere and assume it's permanently there. I tried pulling to a degree on the dishwasher hose (in attached picture) in the hopes it would pull the coupling up, but doesn't look like it will. I'm not sure what to do here. It looks like it would be difficult to snake the new hose through the hole to the sink, and I worry if I try I could make things worse by tangling it on the copper supply line under the floor and crimping it. In the worst case I suppose I could route the new hose through the cabinets to the sink, but that's undesirable.
Is there a reliable way to cut and splice old dishwasher hose to the new one? Even that solution isn't ideal since I still have to use a 15 yr old hose made for a different dishwasher, but would at least use the existing installation.
Thanks for all advice!
