Solar
Discussion in 'Plumbing Tools and Equipment' started by Jcb, Sep 12, 2018.
  1. Sep 12, 2018 #1
    Jcb
    Jcb
    Jcb
    Jul 20, 2017
    9
    Can anyone give any ideas on Pv solar to heat element,to heat small buffer tank,to heat small quantity of rads in a log cabin????
  2. Sep 13, 2018 #2
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    206
    64
    83467
    Huh? I understand the PV solar and heating element. Not sure where your headed from there.
  3. Sep 15, 2018 #3
    Jcb
    Jcb
    Jcb
    Jul 20, 2017
    9
    Just looking for some idea to keep a little heat in log cabin,in winter months while we’re not in it.????
  4. Sep 16, 2018 #4
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    206
    64
    83467
    Just hook a solar panel to an electric heater. Make sure the max output from the solar panel is less than the max wattage of the heater. Do not add: controllers, or batteries, and you may not want the thermostat.
    If you try to go from solar photovoltaic, to a water heater, to a circulating pump, to radiators, you’ve added a lot of complexity, and things that can break.
    Keep it simple, the photovoltaic direct wired to the heaters is as simple as it gets.
  5. Sep 18, 2018 #5
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,009
    196
    North reading, Mass.
    I'm not very familiar with PV solar so must ask, is this to say you can go directly from a panel to a DC powered electric heater? And as it sounds, more than one heater is required. Does that mean each panel to each heater?
  6. Sep 19, 2018 #6
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    206
    64
    83467
    Yes you can wire direct from a panel, or group of panels to get the right voltage, to a resistive heater. Depends on how you set it up on whether you need multiple arrays.
    Diehard likes this.
  7. Sep 19, 2018 #7
    chiraldude
    chiraldude
    chiraldude
    Hardcore DYI-er
    Nov 16, 2013
    104
    24
    Southern Minnesota
    You need to come up with a minimum wattage needed to for your purpose. Then, you need to calculate the number of solar panels needed to get at least that much power. Take in to consideration number of available sun hours given typical cloud cover, trees, terrain, and latitude. (where are you located BTW?)
    Then you need to figure out how to power a heater. Maybe a 12 volt heater but if you are going to wire it directly to the panels, it should be able to work with convection since a blower motor may or may not work with the fluctuating voltage.
    Next level of complexity would be to get some deep cycle batteries and a charging regulator to store the electricity. Then you could have a thermostat that only turns on the heaters when needed. Charge batteries during the day, run heater at night, repeat....
  8. Oct 10, 2018 #8
    Jcb
    Jcb
    Jcb
    Jul 20, 2017
    9
    [okQUOTE="FishScreener, post: 103464, member: 16377"]Yes you can wire direct from a panel, or group of panels to get the right voltage, to a resistive heater. Depends on how you set it up on whether you need multiple arrays.[/QUOTE]
  9. Oct 10, 2018 #9
    Jcb
    Jcb
    Jcb
    Jul 20, 2017
    9
    Ok,thanks lads. Sorry I didn’t get back to you before now.yea I think I will go with panels direct to heater.Just not sure where to buy panels?
  10. Oct 11, 2018 #10
    WyrTwister
    WyrTwister
    WyrTwister
    Dec 6, 2015
    113
    10
    Do you have south facing windows in the cabin ? If so , open up the shades / blinds / curtains . Solar heat . A non cost starting point .
    https://www.harborfreight.com/100-watt-solar-panel-kit-63585.html
    Very rough guess for 100 watts . Typical plug in 120 VAC electric heater = 1500 watts . Do the math .
    Did not find the dimensions of the HF model . You can probably find better pricing on , say 10 - 15 of them .
    If you have comercial AC power or propane heat , the solar looks less practical .
    Wyr
    God bless
  11. Oct 11, 2018 #11
    Mikey
    Mikey
    Mikey
    Well-Known Member Supporting Member
    Jul 16, 2018
    174
    25
    Northwest Washington
    Using the sun to heat water directly is the most efficient - far superior to electric-based. When I lived in Florida, a hurricane passed through and wiped out the grid for close to two weeks. I had a small generator to run the well pump, but cold showers got old pretty quick. I looped a 100' black garden hose on the roof and plumbed it in in series with the water supply to the water heater - Viola! hot showers. If you Google "solar hot water black pipe" you'll find a ton of videos, articles, and websites describing simple ways to heat water.
  12. Oct 11, 2018 #12
    WyrTwister
    WyrTwister
    WyrTwister
    Dec 6, 2015
    113
    10
    Very good plan . The hot water tank is somewhat insulated , so it can store some hot water while the sun is down or it is overcast . Be sure the T&P valve is working properly as there is no control as to the temperature of the " solar heated " water .
    I think a convection flow ( no pump required ) solar heating system can be installed , be sure to use " antifreeze : instead of tap water .
    Wyr
    God bless
  13. Oct 12, 2018 #13
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    206
    64
    83467
    The current cost of solar panels has dropped so far, and the efficiency is so high, that the direct solar water heaters now make little economic sense.
  14. Oct 12, 2018 #14
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    174
    25
  15. Oct 12, 2018 #15
    WyrTwister
    WyrTwister
    WyrTwister
    Dec 6, 2015
    113
    10
    I have a 200 amp 120/240 single phase service for our house . I could get by with a 60 amp service . Any Idea what a PV system for 60 amp service would coast ?
    It would be necessary to take into consideration winter , overcast days and nights year around . Cost of batteries probably is a killer . and they have to be replaced periodically .
    Wyr
    God bless
  16. Oct 31, 2018 #16
    will-b
    will-b
    will-b
    Jan 25, 2018
    16
    Guelph, Ontario
    Solar is the best
Share This Page
