So, I'm not quite certain what he did here
jackplmb
Feb 5, 2020
22
SE PA
My son went through the BIG Freeze in Texas back when. He had damage but not as bad as many.
After things warmed up, he began using his AC. After awhile, he sees water working it's way through a spot on the ceiling.
He pulled the drywall down and discovered the split copper pipe. As it turns out, the pipe is the discharge from the indoor condensate pump from the AC unit.
He put a container on the floor to catch the meager flow when the pump ran to discharge.
This past Friday, he has a plumber come out to fix the split pipe.
After the temporary repair, he gave my son an estimate of $2,200 to do a permanent fix. The high cost due to 'expansion' of the copper pipe.
So, I'm writing this because I'm not exactly certain what he used for this temporary fix.
Let me know what you think he used here.
thanks, jack
PS: as an added bonus, he calls today w/ torrential rains outside and sewerage topping the tub and toilet. Sawzall near ground of exterior clean-out stopped the interior flow but not before bedroom carpets getting pretty bad.
Rickyman
Feb 5, 2018
328
188
That’s actually a piece of the vinyl tubing that comes with a condensation pump for discharge. Like the original installer did I run 3/8” copper for the discharge line so it’s rodent proof. I use about a 6” tail of the vinyl tube from the pump to my copper. D0477E52-2581-4F36-8624-7C98CA64E3F1.jpeg
Riickk
Nov 14, 2019
294
143
Delaware
First, why didn't the plumber just cut out the bad piece of pipe, and solder in a new piece of copper with 2 couplings? Mixing copper & plastic pipe for 1-foot repair makes no sense to me, unless copper is in *really* short supply
Second, why did the builder use what appears to be 1/2" copper for the condensate drain line in the first place? Around here, they usually install clear PVC tubing for a condensate drain; it carries a dribble of water, no pressure whatsoever. PVC plastic lasts for thousands of years, just ask any Green.
JG plumbing
Mar 26, 2021
997
318
Iowa
Minimum size for a condensate drain is 3/4". I would guess a pump could be different. We always run 3/4".
Twowaxhack
Professional
Professional
Feb 9, 2021
2,785
1,096
United states
I’ll describe what I think I see.....
A piece of pex expoxied into copper couplings with hose clamps around them.
A piece of heater hose would’ve been better.....
Rickyman
Feb 5, 2018
328
188
It looks like 3/8” copper, the same size as the refrigerant line next to it. Rodents chew through the vinyl is why we run copper
jackplmb
Feb 5, 2020
22
SE PA
Twowaxhack: That's pretty much what I see though I'm questioning if the clamps have any effect at all.
Rickyman: Yes, rodents are a problem there. Wiring in attic has evidence of this.
Zanne
Mar 23, 2013
2,098
280
Jackplmb, if you are concerned about rodents, spray or spread some peppermint oil (not with any sugar in it) on the areas. Mice don't like peppermint oil. Just make sure you don't spray it near any cats if you have any though. It's deadly to cats (can cause aspiration pneumonia and organ failure) but safe for dogs.
Riickk
Nov 14, 2019
294
143
Delaware
Blew it up and had a close look. Looks to me like a few inches of soft Poly tube pushed over 1/2" copper pipe, then 2 hose clamps to seal & keep it there.
"Stupid is as Stupid does."
jackplmb
Feb 5, 2020
22
SE PA
Thanks Zaane, will forward this to my son in Texas.
jackplmb
Feb 5, 2020
22
SE PA
Could those clamps have any chance of doing anything at all against the copper pipe ?
Riickk
Nov 14, 2019
294
143
Delaware
Can't cause a dissimilar metal corrosion problem, the stainless steel clamps don't touch the copper pipe: The tubing is an insulator.
OTOH, tight clamps should make a decent watertight seal, since there's no pressure.
Twowaxhack
Professional
Professional
Feb 9, 2021
2,785
1,096
United states
I see what they did now. That’s clear tubing against the white background. That’s what was confusing me, it looked like white pipe.
I use an iPhone and sometimes it’s hard to see things the way it really is, for me anyway.
