Slow drain. Bad vent?
Discussion in 'General Plumbing Help' started by 02stangguy, Apr 17, 2019.
  1. Apr 17, 2019 #1
    02stangguy
    02stangguy
    02stangguy
    Dec 15, 2017
    I’d like to get some opinions about a call I went to the other day. The call came in as customers washing machine drain backed up. Looking at the history it shows that our company had been out in the past to snake the drain line. When I arrive I notice that the 2” drain had been re plumbed . The washing machine pumped into a stand pipe, into the trap then a T was put in with a air admittance vent. After the T was a back water valve. About 2 feet after that it connected to a 3x2 fernco which connected to a 3” cast iron Y. The washing machine drained into the back of this 3” y and the kitchen sink drained into the top. The first thing I did was disconnect the fernco and inexpert the 2” line to make sure there were no instructions . No obvious obstructions . I then looked as far down the 3” cast as I could see and it seemed to be clear aside from some normal build up. The 3” cast took a 90 at some point. After I determined the 2” was clean I reconnected it. I then removed the cold water hose from the washing machine and put it in the stand pipe. I slowly started to run water. No back ups. I then turned the valve on all the way and ran it for 5 minutes or so. I removed the cap from the back water valve and watched the water flow right on by along the bottom of the drain.No back ups. I had the customer run the kitchen sink for a extended period of time. No back ups. After that I figured it was time to run the washing machine to test it. I filled the machine and drained it. After draining for some time I heard it start to back up. It sounded like it was about to over flow from the start pipe so I shut it off. I then removed the cap from the back water valve again and filled the washing machine back up. I drained the washing machine and watched the water from the top of the back water valve. The water flowed by with no issues for some time and then I started to see it back up. I turned the machine off. After witnessing that I determined that somewhere in the 3” cast there was a partisan obstruction. I told the customer that the drain needed to be cleaned . The next day a different tech returned to clean the drain. He did some tests for himself as
    Well. First he filled the kitchen sink up and drained it. No issues. After the sink didn’t back up he assumed that the 3” cast was clear and that there was no sort of
    Blockage. He suspected that the stud or vent that vented the washing machine drain was bad. He removed the vent and filled the washing machine up then drained it. According to him it drained without any issues although he did tell
    Me that he could hear the water backing up but it never overflowed . When I tested it I pulled the plug before it had a chance to overflow. So he tells the customer that the drain is fine and he needs a new studor vent. I’m not to convinced that it’s the vent. The biggest reason why I feel that it isn’t the vent is that the second time I drained the washing machine I had the cap
    Off of the back water valve. Even with a bad vent the fact that I had the cap
    Off would have acted as a vent yet I could
    Physically see the water backing up from the back water valve. This guys story is a little twisted. He says he would hear it backing up but never overflowed. Even it he didn’t hear it back up and it drained just fine after he removed the studor vent that still wouldn’t explain why it didn’t drain properly for me when I had that back water valve cap off. My theory is either when it did back up for the customer there was another fixture putting a large volume
    Of water down the drain or there was a partial blockage that cleared itself. What are your
    Thoughts? I’m pretty certain that it will back up again sooner or later .
  2. Apr 17, 2019 #2
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,642
    2,366
    I agree with your conclusion
    here is the deal on a vent, A vents job in the drainage system is to keep the air pressure
    on both sides of the water seal in the p trap equal. And to let sewer [Methane] gas rise up and out the system
  3. Apr 17, 2019 #3
    fixitron
    fixitron
    fixitron
    Feb 22, 2011
    100
    30
    Warren, VT
    sounds similar to a situation I encountered years ago. It was a new addition to a house with the septic going to a new tank. The septic would back up occasionally. It turned out that it would back up when there were a lot of guests there. I discovered that when the building drain was inserted into the tank, it was pushed up against the baffle. When a few loads of turds were flushed down the drain, they could not get by the small gap at the bottom of the pipe (which was installed with a good slope). After the solids dissolved, the drain would clear. It took a saw to cut the pipe at an angle to solve the problem.
    "The more you look, the more you see" "If you don't look, you don't see"
Share This Page
