Hi Folks, this past weekend I visited our mountain camp, with the purpose of changing out our water holding system. The current design is like this: there are 2 250 gallon cylindrical glass lined metal tanks in the rafters. We pump up lake water via a gas powered engine at the lake shoreline, ~40 feet from the camp. The fill line splits at the tanks and fills them simultaneously. Each tank has an overflow line at the top of the tanks, which join to one hose which leads to a shower 8 or so feet away from tanks. Our process is to pump up until water from overflow hose is heard dumping in the shower, and we signal the pumper at the shoreline to cut the engine/pump. This immediately stopped the overflow condition and all was well. The tanks developed leaks, and we decided to go to plastic rectangular tanks from Ca. They each have 2 openings on the top for fill and overflow, and an outlet on bottom to sinks and toilet. We similarly installed the plastic tanks, but did add some valves that we did not have in the old system, that allow for tank isolation. When the new system was installed, we filled up halfway and everything worked like a charm. As we went to test the overflow seals, we discovered a new phenomenon that was not occurring in the old system. Once the overflow condition was reached, and water spilled over to the shower, we cut the pump, but the water did not stop draining into the shower. Seems that a due to the nature of the plastic tanks (perhaps being pliable) it set up conditions for a siphon. So I have two questions....would really like to know a detailed explanation of what is occurring and why, and why the old system did not produce a siphon. The better the explanation (to a layman) the more appreciated! In addition, I am assuming we need to add some kind of a check valve, or something that will introduce air when the overflow occurs. What would be our options, and where would the placement options (for such a valve) be ? THANKS IN ADVANCE !!
