mail4kevino
- Joined
- Dec 24, 2022
- Messages
- 2
- Reaction score
- 0
It’s 3 3/4” The drain tail pipe and p trap set are 1 1/4. Thanks!Those cabinets can be a problem.
Measure from the center of the pipe coming out of the wall to the cabinet bottom for me and post that number.
The Charlotte 1 1/4" P-trap assembly I posted will have a dimension of around 4 1/4" for that, or 1/2" more than you have. It looks like you could make that work by using more than a 1/4" per foot slope to the Sanitary Tee connection that's in the wall, and still not compromise the anti-siphoning reason for the 1/4" per foot slope from that fixture. The length is short enough where that would not be a problem. I'm not sure they make a 1 1/4" P-trap with only a 2" sealing depth, the code minimum, but that would make thing slightly better.It’s 3 3/4” The drain tail pipe and p trap set are 1 1/4. Thanks!
